阅读:6327回复:3
CAD快捷键不能用了
昨天还好好的,今天要编辑一个图纸,发现快捷键不能用了,我要画一条直线,非要打入line才可以,单单一个“L”不行,删除也一样,“E”也不行,非得输入earse才可以,其它的都是这种情况,请高手解答。
发布于:2010-04-15 10:17
搜索查找acad.pgp文件,编辑修改或恢复CAD快捷定义。。。
; -- Sample aliases for AutoCAD commands -- ; These examples include most frequently used commands. 3A, *3DARRAY 3DO, *3DORBIT 3F, *3DFACE 3P, *3DPOLY A, *ARC ADC, *ADCENTER AA, *AREA AL, *ALIGN AP, *APPLOAD AR, *ARRAY -AR, *-ARRAY ATT, *ATTDEF -ATT, *-ATTDEF ATE, *ATTEDIT -ATE, *-ATTEDIT ATTE, *-ATTEDIT B, *BLOCK -B, *-BLOCK BH, *BHATCH BO, *BOUNDARY -BO, *-BOUNDARY BR, *BREAK C, *CIRCLE CH, *PROPERTIES -CH, *CHANGE CHA, *CHAMFER COL, *COLOR COLOUR, *COLOR CO, *COPY D, *DIMSTYLE DAL, *DIMALIGNED DAN, *DIMANGULAR DBA, *DIMBASELINE DBC, *DBCONNECT DCE, *DIMCENTER DCO, *DIMCONTINUE DDA, *DIMDISASSOCIATE DDI, *DIMDIAMETER DED, *DIMEDIT DI, *DIST DIV, *DIVIDE DLI, *DIMLINEAR DO, *DONUT DOR, *DIMORDINATE DOV, *DIMOVERRIDE DR, *DRAWORDER DRA, *DIMRADIUS DRE, *DIMREASSOCIATE DS, *DSETTINGS DST, *DIMSTYLE DT, *DTEXT DV, *DVIEW E, *ERASE ED, *DDEDIT EL, *ELLIPSE EX, *EXTEND EXIT, *QUIT EXP, *EXPORT EXT, *EXTRUDE F, *FILLET FI, *FILTER G, *GROUP -G, *-GROUP GR, *DDGRIPS H, *BHATCH -H, *HATCH HE, *HATCHEDIT HI, *HIDE I, *INSERT -I, *-INSERT IAD, *IMAGEADJUST IAT, *IMAGEATTACH ICL, *IMAGECLIP IM, *IMAGE -IM, *-IMAGE IMP, *IMPORT IN, *INTERSECT INF, *INTERFERE IO, *INSERTOBJ L, *LINE LA, *LAYER -LA, *-LAYER LE, *QLEADER LEN, *LENGTHEN LI, *LIST LINEWEIGHT, *LWEIGHT LO, *-LAYOUT LS, *LIST LT, *LINETYPE -LT, *-LINETYPE LTYPE, *LINETYPE -LTYPE, *-LINETYPE LTS, *LTSCALE LW, *LWEIGHT M, *MOVE MA, *MATCHPROP ME, *MEASURE MI, *MIRROR ML, *MLINE MO, *PROPERTIES MS, *MSPACE MT, *MTEXT MV, *MVIEW O, *OFFSET OP, *OPTIONS ORBIT, *3DORBIT OS, *OSNAP -OS, *-OSNAP P, *PAN -P, *-PAN PA, *PASTESPEC PARTIALOPEN, *-PARTIALOPEN PE, *PEDIT PL, *PLINE PO, *POINT POL, *POLYGON PR, *OPTIONS PRCLOSE, *PROPERTIESCLOSE PROPS, *PROPERTIES PRE, *PREVIEW PRINT, *PLOT PS, *PSPACE PTW, *PUBLISHTOWEB PU, *PURGE -PU, *-PURGE R, *REDRAW RA, *REDRAWALL RE, *REGEN REA, *REGENALL REC, *RECTANGLE REG, *REGION REN, *RENAME -REN, *-RENAME REV, *REVOLVE RM, *DDRMODES RO, *ROTATE RPR, *RPREF RR, *RENDER S, *STRETCH SC, *SCALE SCR, *SCRIPT SE, *DSETTINGS SEC, *SECTION SET, *SETVAR SHA, *SHADE SL, *SLICE SN, *SNAP SO, *SOLID SP, *SPELL SPL, *SPLINE SPE, *SPLINEDIT ST, *STYLE SU, *SUBTRACT T, *MTEXT -T, *-MTEXT TA, *TABLET TH, *THICKNESS TI, *TILEMODE TO, *TOOLBAR TOL, *TOLERANCE TOR, *TORUS TR, *TRIM UC, *DDUCS UCP, *DDUCSP UN, *UNITS -UN, *-UNITS UNI, *UNION V, *VIEW -V, *-VIEW VP, *DDVPOINT -VP, *VPOINT W, *WBLOCK -W, *-WBLOCK WE, *WEDGE X, *EXPLODE XA, *XATTACH XB, *XBIND -XB, *-XBIND XC, *XCLIP XL, *XLINE XR, *XREF -XR, *-XREF Z, *ZOOM |
发布于:2010-04-17 00:07
建议重考一个别人的好的acad.pgp文件覆盖你的那个就行了。
以后养成好习惯,新安装完的cad系统,就备份一个acad。pgp文件 |
