阅读:4653回复:1
关于移动荷载的命令流
/solu
D,1,uy, , , , ,ux D,2,uy, antype,subst tim=0 delt=1 timint,on *do,i,0,64,1 tim=tim+1 time=tim fdele,all,all nsel,all nsel,s,loc,x,(64+i)*0.5 f,all,fy,-220000 nsel,all nsel,s,loc,x,(64+i-3)*0.5 f,all,fy,-220000 nsel,all nsel,s,loc,x,(64+i-6)*0.5 f,all,fy,-220000 nsel,all nsel,s,loc,x,(64+i-9)*0.5 f,all,fy,-220000 nsel,all nsel,s,loc,x,(64+i-12)*0.5 f,all,fy,-220000 nsel,all nsel,s,node,,66+i-15,1,-1 f,all,fy,-46000 nsel,all nsubst,1 outres,all,all solve *enddo finish /post26 axlab,y,uy nsol,2,34,u,y,bx34 nsol,3,66,u,y,bx66 nsol,4,98,u,y,bx98 plvar,2,3,4 |
发布于:2010-06-07 16:13
关于移动荷载的命令流
*SET,long,32 !梁长度32 *SET,ne,100 !单元数量100 *SET,detl,long/ne !定义单元长度 *SET,ii,ne+1 !节点数量100+1 *SET,f,1000 !集中力1000 *SET,v,120 !移动速度120km/h *SET,dett,detl/v*3.6 !每个单元上的时间 !*SET,w,10 !*SET,w,5 *SET,w,1 ! 建模 /config,nres,2000 /prep7 et,1,beam3 ! 定义单元属性 r,1,0.1,0.0001/12,0.1 mp,ex,1,207e9 mp,prxy,1,0.3 mp,dense,1,2000 ! 循环命令创建节点 *do,i,1,ii,1 n,i,(i-1)*detl *enddo !创建单元 *do,i,1,ne e,i,i+1 *enddo finish !加载求解 /sol d,1,all d,101,all ANTYPE,4 !分析类型为瞬态分析 TRNOPT,FULL !解析方法为full法 OUTRES,BASI,ALL !输出每一子步的基本结果 KBC,1.0 !指定荷载步变化为阶越 TIMINT,0 !不考虑瞬态影响 NSUBST,4,8,0 !子步数为4步,最大不超过8步 TIME,1e-10 !加载结束时间1e-10s sstif,on !应力钢化效应打开 ACEL,0,9.8,0, !施加y方向的加速度9.8 solve timint,on !考虑瞬态影响 !施加常力并求解 *do,ii,1,101+8,1 outres,all,all !施加移动荷载 time,ii*dett nsubst,5 *if,ii,lt,8,then fdele,all,all nsel,s,loc,x,(ii-1)*detl f,all,fy,-f allsel solve *elseif,ii,lt,101 fdele,all,all nsel,s,loc,x,(ii-1)*detl nsel,a,loc,x,(ii-1-7)*detl f,all,fy,-f allsel solve *else fdele,all,all nsel,s,loc,x,(ii-7-1)*detl f,all,fy,-f allsel solve *endif *enddo finish !施加匀速简谐力并求解 *do,ii,1,101+8,1 outres,all,all !施加移动荷载 time,ii*dett nsubst,5 *if,ii,lt,8,then fdele,all,all nsel,s,loc,x,(ii-1)*detl f,all,fy,-f*cos(w*ii*dett) allsel solve *elseif,ii,lt,101 fdele,all,all nsel,s,loc,x,(ii-1)*detl nsel,a,loc,x,(ii-1-7)*detl f,all,fy,-f*cos(w*ii*dett) allsel solve *else fdele,all,all nsel,s,loc,x,(ii-7-1)*detl f,all,fy,-f*cos(w*ii*dett) allsel solve *endif *enddo finish /POST26 NSOL,2,51,U,Y,UY_2 ! 定义第二个变量为UY_2,值为50号节点Y方向的位移 XVAR,1 ! 定义时间变量为坐标横轴 PLVAR,2 ! 输出位移图 DERIV,3,2,1,,,,1 ! 将位移对时间求导,得到速度,存为变量3 PLVAR,3 ! 输出速度图 FINISH |
